I have the 1.7.1 version with a player on android.
in version 1.6.4 before I had the “Fix text to area?” for text module.
and since I went through version 1.7.1 I do not have this option that I find beautiful there is there a way to activate the option or should wait for a update
any one have solution for this probleme
That option wasn’t reliable enough and because of that it was removed.
I truly hope so that using CKEditor you will be able to set everything exactly as you want.
Hi thank you for your help you can close this issus
