Cuando programas un evento en Xibo existe una opción en la que te permite seleccionar que se repita diariamente, mensualmente, semanalmente, anualmente, etc. Dentro de estas opciones existe la opción de repetir CADA HORA. ¿Alguien podría explicarme para que sirve esa opción? He estado haciendo pruebas pero no consigo entenderlo.
The above Event will begin today at 12:15 and end at 12:20, repeating every 2 hours. This means that once the Event has finished at 12:20, it will repeat 2 hours later, at 14:15 until 14:20 and then again each 2 hours. If I also set a date in the Until fields under the Repeats tab, it will no longer repeat every 2 hours once that final date has been reached.
I hope this helps you to understand how the Repeat Hourly option works.
Muchas gracias por tu respuesta, pero me surgen nuevas dudas.
¿Funciona igual si programamos el evento con un dayparting determinado?
Por ejemplo, si programo un evento con un dayparting establecido de 10:00 h a 14:00 h y le digo que lo repita cada 1 hora, ¿emitirá a las 10:00 h, 11:00 h, 12:00 h, 13:00 h y 14:00 h?
As you can see, this would mean that you would have up to 4 repeats overlapping each other, which is not necessary. I would not recommend setting any event to repeat every hour if the event itself is over an hour long, or you will get this overlapping repeat as you have described.
