I’ve googled this issue to death and have looked at all issues related here.
Here is my error in the Log:
Unable to reach Forecast API. No Host Found (HTTP Code 0). Curl Error = error setting certificate verify locations:
CAfile: C:\php\cacert.pem
CApath: none
I got the cacert from the curl site by copying the text and pasting it into a notepad file and saving it as cacert.pem. I placed it in the php folder and changed the php.ini file.
I have used that article. However, the error is different. The one in the article linked is able to find the SSL cert, where the one I linked appears to be unable to find it.
