No mail allerts from system
4.2.2 installed with docker on ubuntu OS
windows
Again with e mail allerts, cms is configured to send mail, players ( displays ) are configured as istructions to send email allert(S) when a display goes offline, config.env is correctly configured, checked file and folder onwner (www-data) inside the installation
no mail are sent by system , on log i have this :
472053 27-03-2025 19:23 CONSOLE GET ERROR Unable to send email notification Error: Could not instantiate mail function.
472052 27-03-2025 19:23 CONSOLE GET ERROR Unable to send email notification mail to XXXXXX@sXXXX.com
Can someone help me? thank you
Hello!
I have the same problem here. Same installation, but neither Display alerts nor TFA are working.
The only indication I found is:
host aspmx.l.google.com[142.250.102.27] said: 550-5.7.1 [172.211.223.253] The IP you’re using to send mail is not authorized 550-5.7.1 to send email directly to our servers. Please use the SMTP relay at 550-5.7.1 your service provider instead. For more information, go to 550 5.7.1 'The IP you're using to send email is not authorized...' - Gmail Help
This is in /var/log/mail.log
If you find a solution let me know.
Thank you,
Zoran
no one has answerd yet, i continue to hope someone can help to fix the problem . i got also this error:
7241461 15-04-2025 14:39 CONSOLE GET ERROR Unable to send email notification Error: Could not instantiate mail function.
I think that I have solved it.
Look at this post: TFA and Mails stopped working
