Nginx proxy_pass
Version 2.3.7
Android
R209
Hi everyone,
i’m try to use proxy_pass on vpn connection to CMS mapping 8001 to VPN 80
The authentication work well but the Player dosen’t download media.
There’s some config to do in order to able nginx to download? The FW is disable.
Follow the ngix config:
server {
listen 8001 default_server;
listen [::]:8001 default_server;
root /var/www/html;
index index.html index.htm index.nginx-debian.html;
server_name _;
location / {
proxy_pass http://10.8.0.18:80;
proxy_set_header Host $host;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header X-Forwarded-Proto $scheme;
client_max_body_size 4G;
ThanX
