.Net XiBo Client
I have downloaded the source code for .Net XiBo Client. But i am not able to run it. Its getting struck in the splash screen. Is there any documentation whichtalks atlks about How to run .Net XiBo Client source code.
Sounds like you’re seeing the default layout. It’ll show the default layout until it gets a proper schedule and layouts from the server. You need to set the client configuration options, such as the path to your server. Launch the client using the o (just the letter o, no dash nor slash) command line arg to get to the options screens. Registering a client with a new server
If you’ve already set the server address etc, and on the server-side registered the client, you can press i on the client-side to bring up the information screen. The log entries shown on the information screen will tell you whether it’s in contact with the server, etc. (Dumb question, but here it goes: You have scheduled something to this client, right?)
Thanks for the reply.
I have the server details hosted in the cloud. But i didnt make any changes to the config file. is there any documentation on changing the config file?. I didnt schedule anything. what does it mean, sorry i am very new to XiBo.
The tour will begin as soon as you click the link below.
http://xibo.org.uk/manual/en/tour.html
Also be sure to check out the helpful documentation.
http://xibo.org.uk/manual/en/index.html
