Hej,
We are experimenting if XIBO is the right way to go for our digital signage needs. One of the things we are trying is using the API of the program we use for day to day use.
We have succeeded in creating a dataset, and displaying certain columns in a layout.
But we would like to expand on this. We want to display all events of a certain day that we organise (multiple events in multiple rooms) in the entrance hall of our venue.
We can generate a json file which hold this information but we are having difficulty in putting this into columns.
An event can have multiple instances of a schedule, therefore the json has this data nested. We have not found a way to get this info in columns.
Another question we have is that we have tried using:
Dependant fields: {{COL.NAME}} where NAME is a FieldName from the dependant DataSet
but we are having trouble understanding how to use this. We succeeded in using the {{DATE}}, but we are unsure about what value we need to use for “COL”.
An example of the json file we generate (we adjusted values for security):
“entries”: [
“pagination”: {},
“data”: [
“location”: {
“url”: “https://”,
“id”: “1”,
“name”: “Room 1”,
“_type”: “location”
“schedules”: []
“location”: {
“url”: “https://”,
“id”: “2”,
“name”: “Room 2”,
“_type”: “location”
“schedules”: [
“scheduletype”: “resourcebooking”,
“resourcebooking”: {
“url”: “https://”,
“id”: “RES1”,
“_type”: “resourcebooking”
“start”: “2020-05-11T06:00:00+02:00”,
“end”: “2020-05-12T06:00:00+02:00”,
“actualstart”: null,
“actualend”: null
“location”: {
“url”: “https://”,
“id”: “3”,
“name”: “Room 3”,
“_type”: “location”
“schedules”: [
“url”: “https://”,
“id”: “RES2”,
“start”: “2020-05-11T09:00:00+02:00”,
“end”: “2020-05-11T11:30:00+02:00”,
“actualend”: null
“url”: “https://”,
“id”: “RES3”,
“start”: “2020-05-11T13:00:00+02:00”,
“end”: “2020-05-11T15:30:00+02:00”,
“actualend”: null
