Mute RSTP / live stream region on layout
I would like to know if there any Programmatically or Non-Programmatically way to control the mute and unmute function of client based on regions showing RTSP stream on layout with other multimedia content.
For Example:
From Morning 9 AM to 1 PM - Mute RTSP Stream
From 1 PM to 2 PM - Unmute
From 2 PM to 6 PM - Mute
From 6 PM Onwards - Keep it Unmute till Morning 9 AM
Xibo doesn’t provide any control of the audio on the LocalVideo media type, so I’m afraid you can’t do that as it stands.
I’ll convert your thread over to a feature request so it can be considered for future development.
LocalVideo is the only way Xibo natively plays RTSP content on Android only. On Windows it’s not supported at all at present.
