I wanted to move a dataset to another folder. As far as I found out that is not possible ?
Altering the folder field in the dataset table seems the only way?
Maybe a feature request…
regards,
Jules
regards,
Jules
Hi @evaret,
I’ve tested this on CMS version 4.0.7 and you can move Datasets into other folders from the Datasets page of the CMS by doing the following:
Hi Fraser,
Oops, I did not expect this feature under “edit” , I was looking for a “Select folder” option.
Thanks for your help.
