I am working on a custom extension for Xibo to manage extended data on devices, but I’m finding it hard to find any documentation on the matter.
There is some documentation on making a module for the player (such as the Weather/Google Maps integration) but I’m looking to add/replace links in the Menu and add custom links/integrations on the Device and Layouts and add additional Permissions.
Any custom integration besides modifying the ‘core Xibo’ files? I am able to change core Xibo files but I would need to merge/re-integrate those changes practically every minor version upgrade.
Thank you,
