Module Repair Reinstall
Installation Method
Docker
Operating System
Linux Debian
After i update to 3.1 have problem with modules.
How can i check all the modules files and MD5 and repair? I try verify button but no effect. How can i debug?
If Verify is not working for you we will need further information in order to troubleshoot. What is the problem you are having with modules? Why do you think your module files are to blame?
Thank you
Hey,
If you remove the module, you can’t reinstall. I take a backup and insert at module to reactivate.
