Missing stuff between installations
Version 4.0.8 /4.0.9
Windows
Hello, I’m really new to XIBO. First I made a test installation with docker, then I made a complete Ubuntu 22.04 installation. I noticed some differences in second installation, like templates are missing. I cannot pickup a multiple zone template. If I try to create a fresh template using Zones, I cannot pick up them during Layout configuration…
More, I was wondering where the widgets like weather are located, I saw them on a but cannot see them anywhere.
If I can give you any advice, it’s to stick with docker.
