Right, setting the player libraries to local storage gets rid of the md5 checksum errors. As far as Web Exception errors, I think that is due to a spotty wifi connection - we are using intel sticks to power our displays and the network card on them is flaky.
Here is a log from one of the players that’s spitting out webexception errors:
ScheduleAgentThread|8/6/2015 3:06:03 PM|Error|ScheduleAgent - Run|WebException in Run: The request was aborted: The operation has timed out.
ScheduleAgentThread|8/6/2015 3:06:46 PM|Error|ScheduleAgent - Run|WebException in Run: Unable to connect to the remote server
RegisterAgentThread|8/6/2015 3:07:25 PM|Error|RegisterAgent - Run|WebException in Run: The operation has timed out
ScheduleAgentThread|8/6/2015 3:07:37 PM|Error|ScheduleAgent - Run|WebException in Run: Unable to connect to the remote server
RegisterAgentThread|8/6/2015 3:08:17 PM|Error|RegisterAgent - Run|WebException in Run: Unable to connect to the remote server
RequiredFilesAgentThread|8/6/2015 3:10:21 PM|Error|RequiredFilesAgent - Run|Exception in Run: There is an error in XML document (2, 407).
RequiredFilesAgentThread|8/6/2015 3:11:33 PM|Error|RequiredFilesAgent - Run|WebException in Run: Unable to connect to the remote server
RequiredFilesAgentThread|8/6/2015 3:11:54 PM|Error|RequiredFilesAgent - Run|WebException in Run: Unable to connect to the remote server
ScheduleAgentThread|8/6/2015 3:11:54 PM|Error|ScheduleAgent - Run|WebException in Run: The operation has timed out
RegisterAgentThread|8/6/2015 3:11:59 PM|Error|RegisterAgent - Run|WebException in Run: The operation has timed out
ScheduleAgentThread|8/6/2015 3:16:30 PM|Error|ScheduleAgent - Run|WebException in Run: Unable to connect to the remote server
ScheduleAgentThread|8/6/2015 3:16:30 PM|Error|ScheduleAgent - Run|WebException in Run: The remote name could not be resolved: '<>'
RegisterAgentThread|8/6/2015 3:16:30 PM|Error|RegisterAgent - Run|WebException in Run: The remote name could not be resolved: '<>'
RequiredFilesAgentThread|8/6/2015 3:16:32 PM|Error|RequiredFilesAgent - Run|WebException in Run: Unable to connect to the remote server
ScheduleAgentThread|8/6/2015 3:17:00 PM|Error|ScheduleAgent - Run|WebException in Run: The remote name could not be resolved: '<>'
RegisterAgentThread|8/6/2015 3:17:00 PM|Error|RegisterAgent - Run|WebException in Run: The remote name could not be resolved: '<>'
RequiredFilesAgentThread|8/6/2015 3:17:32 PM|Error|RequiredFilesAgent - Run|WebException in Run: The remote name could not be resolved: '<>'
ScheduleAgentThread|8/6/2015 3:18:00 PM|Error|ScheduleAgent - Run|WebException in Run: The remote name could not be resolved: '<>'
RegisterAgentThread|8/6/2015 3:18:30 PM|Error|RegisterAgent - Run|WebException in Run: The remote name could not be resolved: '<>'
RequiredFilesAgentThread|8/6/2015 3:19:02 PM|Error|RequiredFilesAgent - Run|WebException in Run: The remote name could not be resolved: '<>'
ScheduleAgentThread|8/6/2015 3:20:00 PM|Error|ScheduleAgent - Run|WebException in Run: The remote name could not be resolved: '<>'
RegisterAgentThread|8/6/2015 3:20:30 PM|Error|RegisterAgent - Run|WebException in Run: The remote name could not be resolved: '<>'
RequiredFilesAgentThread|8/6/2015 3:21:32 PM|Error|RequiredFilesAgent - Run|WebException in Run: The remote name could not be resolved: '<>'
RequiredFilesAgentThread|8/6/2015 3:45:55 PM|Error|RequiredFilesAgent - Run|WebException in Run: The operation has timed out
ScheduleAgentThread|8/6/2015 3:47:01 PM|Error|ScheduleAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RegisterAgentThread|8/6/2015 3:49:10 PM|Error|RegisterAgent - Run|Exception in Run: There is an error in XML document (2, 410).
RequiredFilesAgentThread|8/6/2015 3:54:56 PM|Error|RequiredFilesAgent - Run|WebException in Run: The operation has timed out
ScheduleAgentThread|8/6/2015 3:54:56 PM|Error|ScheduleAgent - Run|WebException in Run: The operation has timed out
RegisterAgentThread|8/6/2015 3:58:42 PM|Error|RegisterAgent - Run|Exception in Run: There is an error in XML document (2, 410).
RequiredFilesAgentThread|8/6/2015 4:25:37 PM|Error|RequiredFilesAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
ScheduleAgentThread|8/6/2015 5:32:33 PM|Error|ScheduleAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RegisterAgentThread|8/6/2015 6:08:23 PM|Error|RegisterAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
ScheduleAgentThread|8/7/2015 1:16:47 AM|Error|ScheduleAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
UI Thread|8/7/2015 2:42:34 AM|Error|MainForm - ChangeToNextLayout|Prepare Layout Failed. Exception raised was: The process cannot access the file ‘C:\Users\pu\Documents\Xibo Library\13.xlf’ because it is being used by another process.
UI Thread|8/7/2015 2:42:34 AM|Error|MainForm - ChangeToNextLayout|Layout Change to C:\Users\pu\Documents\Xibo Library\13.xlf failed. Exception raised was: The process cannot access the file ‘C:\Users\pu\Documents\Xibo Library\13.xlf’ because it is being used by another process.
RegisterAgentThread|8/7/2015 2:55:37 AM|Error|RegisterAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RequiredFilesAgentThread|8/7/2015 8:53:10 AM|Error|RequiredFilesAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RequiredFilesAgentThread|8/7/2015 9:49:08 AM|Error|RequiredFilesAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RegisterAgentThread|8/7/2015 1:08:59 PM|Error|RegisterAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
LogAgent|8/7/2015 1:26:14 PM|Error|LogAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
ScheduleAgentThread|8/7/2015 1:26:15 PM|Error|ScheduleAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RequiredFilesAgentThread|8/7/2015 4:13:01 PM|Error|RequiredFilesAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RegisterAgentThread|8/7/2015 5:28:17 PM|Error|RegisterAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RegisterAgentThread|8/7/2015 5:29:52 PM|Error|RegisterAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RequiredFilesAgentThread|8/7/2015 5:31:25 PM|Error|RequiredFilesAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RequiredFilesAgentThread|8/7/2015 6:51:17 PM|Error|RequiredFilesAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RequiredFilesAgentThread|8/7/2015 7:13:15 PM|Error|RequiredFilesAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RequiredFilesAgentThread|8/7/2015 7:33:10 PM|Error|RequiredFilesAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RequiredFilesAgentThread|8/7/2015 8:44:42 PM|Error|RequiredFilesAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
ScheduleAgentThread|8/7/2015 10:12:12 PM|Error|ScheduleAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
ScheduleAgentThread|8/7/2015 11:28:51 PM|Error|ScheduleAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RequiredFilesAgentThread|8/8/2015 12:12:19 AM|Error|RequiredFilesAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RequiredFilesAgentThread|8/8/2015 1:52:28 AM|Error|RequiredFilesAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RequiredFilesAgentThread|8/8/2015 3:09:13 AM|Error|RequiredFilesAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
ScheduleAgentThread|8/8/2015 4:06:55 AM|Error|ScheduleAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
ScheduleAgentThread|8/8/2015 4:32:45 AM|Error|ScheduleAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RequiredFilesAgentThread|8/8/2015 4:42:58 AM|Error|RequiredFilesAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RequiredFilesAgentThread|8/8/2015 5:16:24 AM|Error|RequiredFilesAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
ScheduleAgentThread|8/8/2015 5:47:20 AM|Error|ScheduleAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RegisterAgentThread|8/8/2015 5:57:40 AM|Error|RegisterAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RegisterAgentThread|8/8/2015 5:59:20 AM|Error|RegisterAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RequiredFilesAgentThread|8/8/2015 6:04:19 AM|Error|RequiredFilesAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RegisterAgentThread|8/8/2015 7:41:42 AM|Error|RegisterAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RequiredFilesAgentThread|8/8/2015 7:50:21 AM|Error|RequiredFilesAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
ScheduleAgentThread|8/8/2015 7:50:24 AM|Error|ScheduleAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RequiredFilesAgentThread|8/8/2015 8:29:09 AM|Error|RequiredFilesAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RequiredFilesAgentThread|8/8/2015 8:29:49 AM|Error|RequiredFilesAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RegisterAgentThread|8/8/2015 9:01:56 AM|Error|RegisterAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RegisterAgentThread|8/8/2015 9:12:50 AM|Error|RegisterAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RequiredFilesAgentThread|8/8/2015 9:30:04 AM|Error|RequiredFilesAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RequiredFilesAgentThread|8/8/2015 10:02:03 AM|Error|RequiredFilesAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
ScheduleAgentThread|8/8/2015 10:54:17 AM|Error|ScheduleAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RegisterAgentThread|8/8/2015 10:57:26 AM|Error|RegisterAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RegisterAgentThread|8/8/2015 10:58:58 AM|Error|RegisterAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
ScheduleAgentThread|8/8/2015 10:59:01 AM|Error|ScheduleAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RegisterAgentThread|8/8/2015 11:27:18 AM|Error|RegisterAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
ScheduleAgentThread|8/8/2015 12:05:50 PM|Error|ScheduleAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
ScheduleAgentThread|8/8/2015 12:17:15 PM|Error|ScheduleAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RequiredFilesAgentThread|8/8/2015 12:35:13 PM|Error|RequiredFilesAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RegisterAgentThread|8/8/2015 12:35:13 PM|Error|RegisterAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
ScheduleAgentThread|8/8/2015 12:58:48 PM|Error|ScheduleAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RequiredFilesAgentThread|8/8/2015 1:01:25 PM|Error|RequiredFilesAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RegisterAgentThread|8/8/2015 2:20:42 PM|Error|RegisterAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RegisterAgentThread|8/8/2015 4:13:36 PM|Error|RegisterAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
ScheduleAgentThread|8/8/2015 4:37:49 PM|Error|ScheduleAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RequiredFilesAgentThread|8/8/2015 5:49:04 PM|Error|RequiredFilesAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
ScheduleAgentThread|8/8/2015 6:03:19 PM|Error|ScheduleAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RegisterAgentThread|8/8/2015 6:09:46 PM|Error|RegisterAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RequiredFilesAgentThread|8/8/2015 7:11:37 PM|Error|RequiredFilesAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RegisterAgentThread|8/8/2015 7:51:45 PM|Error|RegisterAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
ScheduleAgentThread|8/8/2015 10:01:33 PM|Error|ScheduleAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RequiredFilesAgentThread|8/8/2015 10:01:35 PM|Error|RequiredFilesAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
ScheduleAgentThread|8/8/2015 10:29:35 PM|Error|ScheduleAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
ScheduleAgentThread|8/8/2015 10:40:21 PM|Error|ScheduleAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RegisterAgentThread|8/8/2015 10:56:10 PM|Error|RegisterAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RegisterAgentThread|8/9/2015 12:05:04 AM|Error|RegisterAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
ScheduleAgentThread|8/9/2015 1:35:01 AM|Error|ScheduleAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RequiredFilesAgentThread|8/9/2015 2:35:21 AM|Error|RequiredFilesAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
ScheduleAgentThread|8/9/2015 2:48:25 AM|Error|ScheduleAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RequiredFilesAgentThread|8/9/2015 2:57:26 AM|Error|RequiredFilesAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
ScheduleAgentThread|8/9/2015 4:14:46 AM|Error|ScheduleAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RegisterAgentThread|8/9/2015 4:19:28 AM|Error|RegisterAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RequiredFilesAgentThread|8/9/2015 4:57:29 AM|Error|RequiredFilesAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
ScheduleAgentThread|8/9/2015 5:16:08 AM|Error|ScheduleAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RegisterAgentThread|8/9/2015 6:26:54 AM|Error|RegisterAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RegisterAgentThread|8/9/2015 6:32:41 AM|Error|RegisterAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
ScheduleManagerThread|8/9/2015 7:26:56 AM|Error|ScheduleManager - LoadNewSchedule|Unable to determine if layout is valid or not
UI Thread|8/9/2015 9:28:59 AM|Error|MainForm - ChangeToNextLayout|Prepare Layout Failed. Exception raised was: The process cannot access the file ‘C:\Users\pu\Documents\Xibo Library\13.xlf’ because it is being used by another process.
UI Thread|8/9/2015 9:28:59 AM|Error|MainForm - ChangeToNextLayout|Layout Change to C:\Users\pu\Documents\Xibo Library\13.xlf failed. Exception raised was: The process cannot access the file ‘C:\Users\pu\Documents\Xibo Library\13.xlf’ because it is being used by another process.
ScheduleAgentThread|8/9/2015 11:53:34 AM|Error|ScheduleAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RequiredFilesAgentThread|8/9/2015 11:59:08 AM|Error|RequiredFilesAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RequiredFilesAgentThread|8/9/2015 12:31:07 PM|Error|RequiredFilesAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RequiredFilesAgentThread|8/9/2015 3:44:38 PM|Error|RequiredFilesAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RequiredFilesAgentThread|8/9/2015 3:49:21 PM|Error|RequiredFilesAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RequiredFilesAgentThread|8/9/2015 5:35:37 PM|Error|RequiredFilesAgent - Run|WebException in Run: Unable to connect to the remote server
RegisterAgentThread|8/9/2015 5:35:39 PM|Error|RegisterAgent - Run|WebException in Run: Unable to connect to the remote server
RequiredFilesAgentThread|8/9/2015 6:15:57 PM|Error|RequiredFilesAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
ScheduleAgentThread|8/9/2015 7:00:29 PM|Error|ScheduleAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RequiredFilesAgentThread|8/9/2015 7:14:38 PM|Error|RequiredFilesAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RequiredFilesAgentThread|8/9/2015 7:15:09 PM|Error|RequiredFilesAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RegisterAgentThread|8/9/2015 7:23:34 PM|Error|RegisterAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RequiredFilesAgentThread|8/9/2015 7:41:52 PM|Error|RequiredFilesAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
ScheduleAgentThread|8/9/2015 8:25:29 PM|Error|ScheduleAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RegisterAgentThread|8/9/2015 9:29:36 PM|Error|RegisterAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RegisterAgentThread|8/9/2015 9:34:45 PM|Error|RegisterAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
ScheduleAgentThread|8/9/2015 10:10:55 PM|Error|ScheduleAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
ScheduleAgentThread|8/9/2015 10:15:32 PM|Error|ScheduleAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
ScheduleAgentThread|8/9/2015 10:18:06 PM|Error|ScheduleAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
ScheduleAgentThread|8/10/2015 12:55:00 AM|Error|ScheduleAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RequiredFilesAgentThread|8/10/2015 3:55:41 AM|Error|RequiredFilesAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RequiredFilesAgentThread|8/10/2015 4:02:59 AM|Error|RequiredFilesAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RegisterAgentThread|8/10/2015 4:12:24 AM|Error|RegisterAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RequiredFilesAgentThread|8/10/2015 4:31:12 AM|Error|RequiredFilesAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
ScheduleAgentThread|8/10/2015 4:39:55 AM|Error|ScheduleAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
ScheduleAgentThread|8/10/2015 6:03:19 AM|Error|ScheduleAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
ScheduleAgentThread|8/10/2015 6:07:56 AM|Error|ScheduleAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
ScheduleAgentThread|8/10/2015 6:14:36 AM|Error|ScheduleAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RequiredFilesAgentThread|8/10/2015 7:35:11 AM|Error|RequiredFilesAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RequiredFilesAgentThread|8/10/2015 8:34:32 AM|Error|RequiredFilesAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RequiredFilesAgentThread|8/10/2015 9:35:51 AM|Error|RequiredFilesAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RequiredFilesAgentThread|8/10/2015 9:42:29 AM|Error|RequiredFilesAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RequiredFilesAgentThread|8/10/2015 9:58:52 AM|Error|RequiredFilesAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
ScheduleAgentThread|8/10/2015 10:25:37 AM|Error|ScheduleAgent - Run|WebException in Run: The remote name could not be resolved: '<>'
ScheduleAgentThread|8/10/2015 11:59:17 AM|Error|ScheduleAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
ScheduleAgentThread|8/10/2015 1:18:16 PM|Error|ScheduleAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RegisterAgentThread|8/10/2015 2:38:22 PM|Error|RegisterAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RequiredFilesAgentThread|8/10/2015 3:02:04 PM|Error|RequiredFilesAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
ScheduleAgentThread|8/10/2015 3:22:44 PM|Error|ScheduleAgent - Run|WebException in Run: The request was aborted: The operation has timed out.
RegisterAgentThread|8/10/2015 3:23:05 PM|Error|RegisterAgent - Run|WebException in Run: Unable to connect to the remote server
RegisterAgentThread|8/10/2015 3:47:00 PM|Error|RegisterAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RequiredFilesAgentThread|8/10/2015 4:43:18 PM|Error|RequiredFilesAgent - Run|WebException in Run: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.
RegisterAgentThread|8/10/2015 4:43:32 PM|Error|RegisterAgent - Run|WebException in Run: The underlying connection was closed: An unexpected error occurred on a receive.
RegisterAgentThread|8/10/2015 4:44:23 PM|Error|RegisterAgent - Run|Exception in Run: There is an error in XML document (2, 410).
ScheduleAgentThread|8/10/2015 4:44:58 PM|Error|ScheduleAgent - Run|WebException in Run: The operation has timed out
