Maintenance Script Help
I need help!!! my Database is currently 955mb, and I seem to run the script.
http://ceyorks.org/xibo/maintenance.php?key=(*&^%$£%^&
and it come up
Email Alerts
XXXXXXXXXXXXXXXXXXXXXXXXXXXXX
Tidy Logs
Done.
Tidy Stats
Done.
Wake On LAN
Done.
But doesn’t have seem to shrunk the DB. Please Help
Try going to Media and Tidy Library
Nope hasn’t effected it!!
Ok, try truncating the log, but it does sound like the maintenance script is not running correctly.
What OS is the CMS running on? Which version of the CMS?
Also tried that, log seems to appear again
On a Linux webserver, and the lastest 1.7.5
Permissions issue?? Are the running the maintenance script from the browser or using cron?
Running from my brower
You might try running it from the command line and scheduling it in cron.
Thank you, will look into Cron. It has reduced to 155mb now, what is the standard sort of size,
Nice.
There is not really a standard size. The size of the database will vary with number of displays, number of layouts, datasets, data collection intervals, frequency of the maintenance script being ran and more. But the biggest factors are your log collection settings and how often the maintenance script is ran.
