Log files: Microsoft OneDrive - Access files anywhere. Create docs with free Office Online.
"app_ver": "3.0.6",
"XmdsVersion": "6",
"XlfVersion": 3
Installation Method
Docker
Operating System
Ubuntu, latest
I cannot open the maintenance view http:///maint?key=changeme
Tested with protected mode and without.
Slim Application Error
The application could not run because of the following error:
Details
Type: Xibo\Support\Exception\InvalidArgumentException
Code: 422
Message:
File: /var/www/cms/vendor/xibosignage/support/src/Xibo/Support/Sanitizer/RespectSanitizer.php
Line: 86
Trace
#0 /var/www/cms/vendor/xibosignage/support/src/Xibo/Support/Sanitizer/RespectSanitizer.php(174): Xibo\Support\Sanitizer\RespectSanitizer->failure()
#1 /var/www/cms/lib/Factory/TaskFactory.php(139): Xibo\Support\Sanitizer\RespectSanitizer->getString()
#2 /var/www/cms/lib/Factory/TaskFactory.php(65): Xibo\Factory\TaskFactory->query()
#3 /var/www/cms/lib/Controller/Task.php(449): Xibo\Factory\TaskFactory->getById()
#4 /var/www/cms/lib/Controller/Maintenance.php(208): Xibo\Controller\Task->run()
#5 /var/www/cms/lib/Controller/Maintenance.php(162): Xibo\Controller\Maintenance->runTask()
#6 [internal function]: Xibo\Controller\Maintenance->run()
#7 /var/www/cms/vendor/php-di/invoker/src/Invoker.php(82): call_user_func_array()
#8 /var/www/cms/vendor/php-di/slim-bridge/src/ControllerInvoker.php(47): Invoker\Invoker->call()
#9 /var/www/cms/vendor/slim/slim/Slim/Routing/Route.php(384): DI\Bridge\Slim\ControllerInvoker->__invoke()
#10 /var/www/cms/vendor/slim/slim/Slim/MiddlewareDispatcher.php(81): Slim\Routing\Route->handle()
#11 /var/www/cms/vendor/slim/slim/Slim/MiddlewareDispatcher.php(81): Slim\MiddlewareDispatcher->handle()
#12 /var/www/cms/vendor/slim/slim/Slim/Routing/Route.php(341): Slim\MiddlewareDispatcher->handle()
#13 /var/www/cms/vendor/slim/slim/Slim/Routing/RouteRunner.php(84): Slim\Routing\Route->run()
#14 /var/www/cms/lib/Middleware/Log.php(59): Slim\Routing\RouteRunner->handle()
#15 /var/www/cms/vendor/slim/slim/Slim/MiddlewareDispatcher.php(147): Xibo\Middleware\Log->process()
#16 /var/www/cms/lib/Middleware/State.php(87): class@anonymous->handle()
#17 /var/www/cms/vendor/slim/slim/Slim/MiddlewareDispatcher.php(147): Xibo\Middleware\State->process()
#18 /var/www/cms/vendor/slim/twig-view/src/TwigMiddleware.php(125): class@anonymous->handle()
#19 /var/www/cms/vendor/slim/slim/Slim/MiddlewareDispatcher.php(147): Slim\Views\TwigMiddleware->process()
#20 /var/www/cms/lib/Middleware/Storage.php(61): class@anonymous->handle()
#21 /var/www/cms/vendor/slim/slim/Slim/MiddlewareDispatcher.php(147): Xibo\Middleware\Storage->process()
#22 /var/www/cms/lib/Middleware/Xmr.php(67): class@anonymous->handle()
#23 /var/www/cms/vendor/slim/slim/Slim/MiddlewareDispatcher.php(147): Xibo\Middleware\Xmr->process()
#24 /var/www/cms/vendor/slim/slim/Slim/Middleware/RoutingMiddleware.php(59): class@anonymous->handle()
#25 /var/www/cms/vendor/slim/slim/Slim/MiddlewareDispatcher.php(147): Slim\Middleware\RoutingMiddleware->process()
#26 /var/www/cms/vendor/slim/slim/Slim/Middleware/ErrorMiddleware.php(107): class@anonymous->handle()
#27 /var/www/cms/vendor/slim/slim/Slim/MiddlewareDispatcher.php(147): Slim\Middleware\ErrorMiddleware->process()
#28 /var/www/cms/vendor/slim/slim/Slim/MiddlewareDispatcher.php(81): class@anonymous->handle()
#29 /var/www/cms/vendor/slim/slim/Slim/App.php(215): Slim\MiddlewareDispatcher->handle()
#30 /var/www/cms/vendor/slim/slim/Slim/App.php(199): Slim\App->handle()
#31 /var/www/cms/web/maint/index.php(102): Slim\App->run()
#32 {main}
