CMS Version:
Xibo CMS 3.3.5
Issue:
I need assistance configuring LDAP authentication for my Xibo CMS (version 3.3.5). My goal is to allow users to log in using credentials from our local LDAP servers. Here are some key points to consider:
Environment Setup:
- My LDAP servers are local and do not have SAML installed.
- Both the Xibo CMS and the LDAP servers are within the same LAN and can communicate with each other.
- The CMS is not accessible from outside our private network.
Problem:
- I’m not sure how to configure Xibo to use LDAP for authentication.
- I’ve seen mentions of SAML as a workaround, but since our LDAP servers don’t support SAML, I’m looking for a direct LDAP integration solution.
Can you guide me on how to configure LDAP authentication for Xibo CMS in this setup? Any detailed steps or documentation links would be greatly appreciated.
Thank you for your help!
