I have scheduled several video’s. Each video plays around 45 minutes.
The filesize is around 3,5gb.
I didn’t loop the local video are the region. The duration of the video is around 2700 seconds.
I use Xampp for the local cms and Windows client.
The problem:
After the first 6 minutes and 30 seconds each video restarts automatically.
After that the video plays till the end of scheduled time is completed.
I think the problem has to do with the php.ini. But I can’t find out what the problem is.
It’s unlikely to be anything to do with your php.ini file.
What duration have you set on the videos? Try setting them to 0 (automatic) so they detect the end automatically.
Restarting part way through is likely due to a change in the layout being received by the Player so it’s restarting the layout to take that change in to account.
What version? And on what version of Windows? To be clear you’ve copied the videos somewhere locally on each Player and then loaded them with the LocalVideo module? Does it happen on all Players or only on one?
Btw I changed a lot of number in the php.ini and for what I can see now the video restarts around 28 minutes. Just to see if there where any changes.
For example:
max_execution_time=30000
max_input_time=60000
pdo_mysql.cache_size=10000
etc.
Changes to the php.ini file can’t effect the Player. It doesn’t use PHP or run php in any way.
If the layout is reloading part way through, I would suggest something is changing the layout on the CMS and therefore the Player restarts to show those changes. Please be sure nothing is changed on the CMS while the layout plays. You could even turn off the option to expire modified layouts on the Display Settings profile for your player.
My understanding of your problem is that it is a player issue and not a CMS issue. I.e. you have installed the CMS somewhere, connected a player to it and you are now trying to play videos from 2 players.
1 player works fine, the other does not… they share the same CMS.
So you aren’t looking for any differences in the CMS - you are looking for something on the Player - are they the same versions, same O/S - have you transferred the same videos to the same local folder, etc
