I’ve been playing around with Xibo for a few weeks now. I have one of an intended 4 or so screens running with content just by playing around and I’m really impressed.
I have a couple of datasets being populated from APIs. A couple of these will be being displayed in charts so that will be fine but I’d like to use the data from one of them inside a block of text. Is there a way to call data from a row into text such as the way the data or time is able to be called with “Snippets” in the text editor?
That’s great to hear! There are quite a few Widgets that work with DataSets, DataSet Ticker being one which will allow you to pull in data to display as a block of text which you can optionally set effects or leave as static.
Do let us know if this provides a solution for you
