Linux Player Questions
  1. Where is the log file stored or configured?
  2. I know Ubuntu Server is recommended, but is there a recommended DE/WM?
De = Desktop Environment I assume? Mostly due to my Intel iris xe graphics, I opted for fedora desktop and used snap to install xibo. The results were underwhelming
Fedora isn’t a Desktop Environment, but you are likely on Gnome.
I tried KDE Plasma but couldn’t get the scaling how I wanted.
Sorry i should be more specific. I didn’t use Ubuntu, i used Fedora , with whatever the desktop skin it comes with. For video scaling, check your graphics driver, and current kernel. i’ve found fedora runs intel iris graphics much smoother than ubuntu, whereas AMD seems to run beautifully on ubuntu.
