I have an embedded website in my layout. It displays a grafana screen with several stats. It works like a charm on Android. It doesn’t display anything on Linux.
Any ideas or inspirations where I can find a solution?
im sure someone from the team will msg but just wanted to say that the linux client is pretty buggy and they do not have a developer for it at this time, so i highly suggest you use the windows client if possible.
