Hi All,
Since the Linux player does not work as expected using the same hardware as we did using the Windows player (running Windows), I am looking for hardware recommendations.
Currently, under Windows, we are using these Intel Stick PC’s: Intel® Compute Stick STK1AW32SC. We would like to keep the form factor as small as possible since mounting can be a challenge.
Thanks in advance
