Limit on Data Set view?
v3 303
I have a layout that sorts a data set into 7 different regions , in effect it is taking a fixture list, and displaying the data for each day in its own region. I have been having issues with the layout not playing on the screens. however if I delete one of the data set view regions it all works perfectly , so it seems that there is a limit somewhere that is preventing me having 7 regions all pulling different data from the same data set. all help appreciated
Provide screenshots where possible!
There should be no hard limit on the number of regions for the Windows player, it is most likely to be a resources issue as you would be running at least 7 web browsers, which would consume a lot of RAM in the process.
Thanks Natasha that makes sense , I will check it out
