Hi, it is possible to use Xibo Android v2 (without v2 new features, just in legacy for 1.8) with and old license for 1.8 or it’s mandatory to upgrade the license too?
Thanks in advance
Thanks in advance
Thank you for your message. To use Version 2 of the Xibo for Android Player, you will indeed need a V2 License. As you have mentioned, you can do this upgrading an existing 1.8 License or by purchasing a new License.
