Hello.
I’ve been trying to setup xibo for android to run on led screen without luck. My device is tx3 mini. Led screen resolution is 416x832.
When I make 1080p layout and make region 416x832 it works perfectly, but fly transition looks awful.
I’ve made custom resolution and layout using it, and I’ve setup player profile screen dimensions to be 0,0,416,832. However, when I restart player it doesn’t show whole layout. Kinda looks like it switched to 720p output making my layout too wide and bottom cut off, although my testing screen still reports it’s 1080p. When I set orientation to portrait, scaling is good but starting coordinates are off like it’s centered on a widescreen.
I tried it with custom resolution from your example (200x100) and it seems to work fine.
