Layout Status showing “This Layout is invalid and should not be Scheduled” Why?
Perhaps it has an empty region in it?
If you won’t be able to fix it, you can export it, upload it to dropbox/similar and share the download link here or via pm. Then I’ll have a look.
If you are still using 1.4 (as per your previous topic) then unfortunately you won’t be able to export your layout. But as I said the most common cause for layout to be rendered as invalid (in CMS) is an empty region.
