Does the screen/PC go in to power saving or similar overnight? Or reboot automatically or similar.
The player if set to use Full Screen will use the screen dimensions it gets at startup. Sometimes if a machine reboots or hibernates then the screen size we see changes.
You could try fixing the size/position of the Player with a Display Settings Profile for that Player.
