preis
1
Hi.
I’ve installed the player version 1.8-R5 using snap package as described in documentation.
Also the setup is done as told.
The player works correctly but when I run Xibo player from terminal I get this error:
“Layout (XLF File) is invalid or missing."
Just spend some time in the community forums searching by a similar issue but no luck so far.
Captura de ecrã de 2020-09-02 16-38-55|690x431
I could send you also the troubleshot.zip file in a PM generated by the Reporting Fault.
Can you help me?
Thanks.
preis
2
I’ve already done these:
- uninstall Xibo Player and snap package
- install the lasted snap package with Xibo Player
- configured the Player options
- set permissions to local library (sudo chmod -R 650 /my-xibolibrary-folder)
- connected the Player to the CMS
- authorized of the Display with the CMS
It’s seems that the layouts are nor transferred from the CMS to the Player. The library folder is empty!
I’m using a local network with no constrains. Just using a switch hub and wires. The server and the client are reached in both ways (ping ip address).
I’m really stuck
system
Closed
3
