Layout Designer - Weather Widget Slow To Load
Docker 3.3.8
DSCS9X
R311
When working with the Weather widget from within the Layout Designer, there is always a 15s delay before the widget options appear.
Here is a video of the issue:
This problem has been with us since we upgraded our CMS from v2 → v3. We cannot for the life of us figure out the root of the issue. We’ve scanned through all of the logs, verified the modules and Inspected the HTML traffic from within the web session to no avail.
We tried to reproduce this error on a fresh Docker container but were not successful.
@dan I’m sure you are very busy, but we could really use some dev expertise here in tracking down the issue…
Thanks for your time! :slight_smile:
I think you’ll need to open Chrome developer tools and use the Network tab to see exactly which request is taking the time.
If you want to post a screenshot of that here, i’d be happy to look at it.
Thanks for getting back to us! We would be happy to provide any information that you need to help us narrow down the cause of the issue. I apologize that the video from the previous post is no longer available. Here is an updated one with network inspection:
https://jumpshare.com/embed/l3MNsVhfFm0PXjWeJuqx
Here is the Chrome: Inspect: Network page when clicking on an assigned Weather widget from the Layout Designer:
It would appear that there is a request to 137225 that is 40MB in size and took 13.42s to complete. While this request is churning away, the Properties of the widget just spins away ‘loading’.
Thanks for your input.
Holy moley… after that 40MB request has downloaded, can you click on it and see what the headers/payload and response say?
I’m not sure how valuable this file will be to you, but I may have to locate a separate means to upload it to you more securely, in case it contains any private CMS data. In a nutshell, however, it’s a bunch of HTML code with options and lots of imports_ media files, something that looks like endless scrolling walls of text like this:
Is this enough for you to go on, do I need to find a way to get all of these over to you to browse through?
Thanks.
Sorry do you have the headers/payload tabs too? I can’t see from the screenshot what the actual request is (I presume its for getting the form, but i’d like to be sure).
It certainly looks like there is some sort of circular reference involved - do you perhaps have the [dailyTemplate] replacement inside the [dailyTemplate] itself?
No, we don’t have anything like that. We have kept things pretty vanilla to the docker container. I have a hunch based what I’m seeing in the response data, that it’s populating the Media image dropdown options that can be used for the various weather conditions such as Cloudy, Cloudy day, Clear, etc. It would appear though that it returns the results of those options 10 times, one for each of the elements.
Request Header
GET /playlist/widget/form/edit/137225 HTTP/1.1
Accept: */*
Accept-Encoding: gzip, deflate, br
Accept-Language: en-US,en;q=0.9
Connection: keep-alive
Cookie: filtered
Host: example.org
Referer: https://example.org/layout/designer/19161
Sec-Fetch-Dest: empty
Sec-Fetch-Mode: cors
Sec-Fetch-Site: same-origin
User-Agent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36
X-Requested-With: XMLHttpRequest
X-XSRF-TOKEN: 8651d81e8d96fc145f2da58f302b1a1f1d0171b7
sec-ch-ua: "Not_A Brand";v="8", "Chromium";v="120", "Google Chrome";v="120"
sec-ch-ua-mobile: ?0
sec-ch-ua-platform: "macOS"
Response Header
HTTP/1.1 200 OK
Date: Fri, 15 Dec 2023 15:42:54 GMT
Server: Apache/2.4.56 (Unix)
X-Frame-Options: SAMEORIGIN
X-Content-Type-Options: nosniff
Content-Security-Policy: frame-ancestors 'self'
Connection: close
Transfer-Encoding: chunked
Content-Type: application/json
Response Payload Excerpt:
Lines  1-638:
HTML Response Data
<div class="row">
	<ul class="nav nav-tabs" role="tablist">
		<li class="nav-item">
			<a class="nav-link active" href="#general" role="tab" data-toggle="tab">
				<span>General</span>
			</a>
		</li>
			<a class="nav-link" href="#configurationTab" role="tab" data-toggle="tab">
				<span>Configuration</span>
			</a>
		</li>
		<li class="nav-item dropdown">
			<a class="nav-link dropdown-toggle" data-toggle="dropdown" href="#" role="button" aria-haspopup="true" aria-expanded="false">
 Templates
				<span class="caret"></span>
			</a>
			<div class="dropdown-menu">
				<a class="dropdown-item" href="#templatePreset" role="tab" data-toggle="tab">
					<span>Preset</span>
				</a>
				<a class="dropdown-item template-override-controls" href="#currentForecastTab" role="tab" data-toggle="tab">
					<span>Current Forecast</span>
				</a>
				<a class="dropdown-item template-override-controls" href="#dailyForecastTab" role="tab" data-toggle="tab">
					<span>Daily Forecast</span>
				</a>
				<a class="dropdown-item template-override-controls" href="#optionalStylesheetTab" role="tab" data-toggle="tab">
					<span>Style Sheet</span>
				</a>
				<a class="dropdown-item" href="#optionalJavascript" role="tab" data-toggle="tab">
					<span>Optional JavaScript</span>
				</a>
			</div>
		</li>
			<a class="nav-link" href="#cacheTab" role="tab" data-toggle="tab">
				<span>Caching</span>
			</a>
		</li>
			<a class="nav-link" href="#forecast" role="tab" data-toggle="tab">
				<span>Forecast</span>
			</a>
		</li>
	</ul>
	<div class="col-md-12">
		<form id="forecastEditForm" class="XiboForm form-horizontal" method="put" action="/playlist/widget/137225">
			<div class="tab-content">
				<div class="tab-pane active" id="general">
					<div class="form-group row ">
						<label class="col-sm-2 control-label" for="name" accesskey="">Name</label>
						<div class="col-sm-10">
							<input class="form-control" name="name" type="text" id="name" value="Test Forecast" />
							<small class="form-text text-muted">An optional name for this widget</small>
						</div>
					</div>
						<div class="offset-sm-2 col-sm-10">
							<div class="form-check">
								<input class="form-check-input" type="checkbox" id="useDuration" name="useDuration" >
									<label class="form-check-label" for="useDuration" accesskey="">Set a duration?</label>
								</div>
								<small class="form-text text-muted">Select to provide a specific duration for this Widget</small>
							</div>
						</div>
						<div class="form-group row duration-fields">
							<label class="col-sm-2 control-label" for="duration" accesskey="">Duration</label>
								<input class="form-control" name="duration" type="number" id="duration" value="60" required />
								<small class="form-text text-muted">The duration in seconds this item should be displayed.</small>
							</div>
						</div>
							<label class="col-sm-2 control-label" for="enableStat" accesskey="">Enable Stats Collection?</label>
								<select class="form-control" name="enableStat" id="enableStat">
									<option value="Off">Off</option>
									<option value="On">On</option>
									<option value="Inherit" selected
 >Inherit</option>
								</select>
								<small class="form-text text-muted">Enable the collection of Proof of Play statistics for this Widget. Ensure that \u2018Enable Stats Collection\u2019 is set to \u2018On\u2019 in the Display Settings.</small>
							</div>
						</div>
					</div>
					<div class="tab-pane" id="configurationTab">
									<input class="form-check-input" type="checkbox" id="useDisplayLocation" name="useDisplayLocation" checked >
										<label class="form-check-label" for="useDisplayLocation" accesskey="">Use the Display Location</label>
									</div>
									<small class="form-text text-muted">Use the location configured on the display</small>
								</div>
							</div>
							<div class="form-group row locationControls">
								<label class="col-sm-2 control-label" for="latitude" accesskey="">Latitude</label>
									<input class="form-control" name="latitude" type="number" id="latitude" value="" />
									<small class="form-text text-muted">The Latitude for this widget</small>
								</div>
							</div>
								<label class="col-sm-2 control-label" for="longitude" accesskey="">Longitude</label>
									<input class="form-control" name="longitude" type="number" id="longitude" value="" />
									<small class="form-text text-muted">The Longitude for this widget</small>
								</div>
							</div>
								<label class="col-sm-2 control-label" for="units" accesskey="">Units</label>
									<select class="form-control" name="units" id="units">
										<option value="auto" selected
 >Automatically select based on geographic location</option>
										<option value="ca">Canada</option>
										<option value="si">Standard International Units</option>
										<option value="uk2">United Kingdom</option>
										<option value="us">United States</option>
									</select>
									<small class="form-text text-muted">Select the units you would like to use.</small>
								</div>
							</div>
								<label class="col-sm-2 control-label" for="lang" accesskey="">Language</label>
									<select class="form-control" name="lang" id="lang">
										<option value="af">Afrikaans</option>
										<option value="ar">Arabic</option>
										<option value="az">Azerbaijani</option>
										<option value="bg">Bulgarian</option>
										<option value="ca">Catalan</option>
										<option value="zh_cn">Chinese Simplified</option>
										<option value="zh_tw">Chinese Traditional</option>
										<option value="cz">Czech</option>
										<option value="da">Danish</option>
										<option value="de">German</option>
										<option value="el">Greek</option>
										<option value="en" selected
 >English</option>
										<option value="eu">Basque</option>
										<option value="fa">Persian (Farsi)</option>
										<option value="fi">Finnish</option>
										<option value="fr">French</option>
										<option value="gl">Galician</option>
										<option value="he">Hebrew</option>
										<option value="hi">Hindi</option>
										<option value="hr">Croatian</option>
										<option value="hu">Hungarian</option>
										<option value="id">Indonesian</option>
										<option value="it">Italian</option>
										<option value="ja">Japanese</option>
										<option value="kr">Korean</option>
										<option value="la">Latvian</option>
										<option value="lt">Lithuanian</option>
										<option value="mk">Macedonian</option>
										<option value="no">Norwegian</option>
										<option value="nl">Dutch</option>
										<option value="pl">Polish</option>
										<option value="pt">Portuguese</option>
										<option value="pt_br">Portugu\u00eas Brasil</option>
										<option value="ro">Romanian</option>
										<option value="ru">Russian</option>
										<option value="se">Swedish</option>
										<option value="sk">Slovak</option>
										<option value="sl">Slovenian</option>
										<option value="es">Spanish</option>
										<option value="sr">Serbian</option>
										<option value="th">Thai</option>
										<option value="tr">Turkish</option>
										<option value="uk">Ukrainian</option>
										<option value="vi">Vietnamese</option>
										<option value="zu">Zulu</option>
									</select>
									<small class="form-text text-muted">Select the language you would like to use.</small>
								</div>
							</div>
										<input class="form-check-input" type="checkbox" id="dayConditionsOnly" name="dayConditionsOnly" >
											<label class="form-check-label" for="dayConditionsOnly" accesskey="">Only show Daytime weather conditions</label>
										</div>
										<small class="form-text text-muted">Tick if you would like to only show the Daytime weather conditions.</small>
									</div>
								</div>
								<div class="form-group row align-fields">
									<label class="col-sm-2 control-label" for="alignH" accesskey="">Horizontal Align</label>
										<select class="form-control" name="alignH" id="alignH">
											<option value="left">Left</option>
											<option value="center" selected
 >Centre</option>
											<option value="right">Right</option>
										</select>
										<small class="form-text text-muted">How should this widget be aligned?</small>
									</div>
								</div>
									<label class="col-sm-2 control-label" for="alignV" accesskey="">Vertical Align</label>
										<select class="form-control" name="alignV" id="alignV">
											<option value="top">Top</option>
											<option value="middle" selected
 >Middle</option>
											<option value="bottom">Bottom</option>
										</select>
										<small class="form-text text-muted">How should this widget be vertically aligned?</small>
									</div>
								</div>
							</div>
							<div class="tab-pane" id="templatePreset">
								<div class="form-group row template-selector-control">
									<label class="col-sm-2 control-label" for="templateType" accesskey="">Type</label>
										<select class="form-control" name="templateType" id="templateType">
											<option value="" selected
 >All</option>
											<option value="current">Current</option>
											<option value="forecast">Forecast</option>
										</select>
										<small class="form-text text-muted">Choose the type of template</small>
									</div>
								</div>
									<label class="col-sm-2 control-label" for="templateOrientation" accesskey="">Orientation</label>
										<select class="form-control" name="templateOrientation" id="templateOrientation">
 >All</option>
											<option value="square">Square</option>
											<option value="landscape">Landscape</option>
											<option value="portrait">Portrait</option>
											<option value="scale">Scale</option>
										</select>
										<small class="form-text text-muted">Choose the orientation of template</small>
									</div>
								</div>
								<div class="form-group row template-selector-control localSelect selectPickerWithImage">
									<label class="col-sm-2 control-label" for="templateId" accesskey="">Template</label>
										<select class="form-control" name="templateId" id="templateId"
 data-minimum-results-for-search="Infinity"
 data-width="100%">
											<option value="weather-module0-5day" selected data-content="
												<span class='media'>
													<span class='media-left mr-2'>
														<img style='max-width: 100px; max-height: 80px;' src='/playlist/widget/form/templateimage/forecastio/weather-module0-5day' />
													</span>
													<span class='media-body'>Landscape - Current day, 4 day forecast</span>
												</span>"
 data-filter0-class="forecast"
 data-filter1-class="landscape">Landscape - Current day, 4 day forecast
											</option>
											<option value="weather-module0-singleday" data-content="
														<img style='max-width: 100px; max-height: 80px;' src='/playlist/widget/form/templateimage/forecastio/weather-module0-singleday' />
													</span>
													<span class='media-body'>Landscape - Current day, summary</span>
												</span>"
 data-filter0-class="current"
 data-filter1-class="landscape">Landscape - Current day, summary
											</option>
											<option value="weather-module0-singleday2" data-content="
														<img style='max-width: 100px; max-height: 80px;' src='/playlist/widget/form/templateimage/forecastio/weather-module0-singleday2' />
													</span>
													<span class='media-body'>Landscape - Current day</span>
												</span>"
											</option>
											<option value="weather-module1l" data-content="
														<img style='max-width: 100px; max-height: 80px;' src='/playlist/widget/form/templateimage/forecastio/weather-module1l' />
													</span>
													<span class='media-body'>Landscape - Current day detailed, 4 day forecast</span>
												</span>"
 data-filter1-class="landscape">Landscape - Current day detailed, 4 day forecast
											</option>
											<option value="weather-module1p" data-content="
														<img style='max-width: 100px; max-height: 80px;' src='/playlist/widget/form/templateimage/forecastio/weather-module1p' />
													</span>
													<span class='media-body'>Portrait - Current day, 2 day forecast</span>
												</span>"
 data-filter1-class="portrait">Portrait - Current day, 2 day forecast
											</option>
											<option value="weather-module-10l" data-content="
														<img style='max-width: 100px; max-height: 80px;' src='/playlist/widget/form/templateimage/forecastio/weather-module-10l' />
													</span>
													<span class='media-body'>Landscape - Weather fullscreen</span>
												</span>"
 data-filter1-class="landscape">Landscape - Weather fullscreen
											</option>
											<option value="weather-module2l" data-content="
														<img style='max-width: 100px; max-height: 80px;' src='/playlist/widget/form/templateimage/forecastio/weather-module2l' />
													</span>
													<span class='media-body'>Landscape - Current day detailed table, 4 day forecast</span>
												</span>"
 data-filter1-class="landscape">Landscape - Current day detailed table, 4 day forecast
											</option>
											<option value="weather-module2p" data-content="
														<img style='max-width: 100px; max-height: 80px;' src='/playlist/widget/form/templateimage/forecastio/weather-module2p' />
													</span>
													<span class='media-body'>Square - Current day</span>
												</span>"
 data-filter1-class="square">Square - Current day
											</option>
											<option value="weather-module3l" data-content="
														<img style='max-width: 100px; max-height: 80px;' src='/playlist/widget/form/templateimage/forecastio/weather-module3l' />
													</span>
												</span>"
											</option>
											<option value="weather-module3p" data-content="
														<img style='max-width: 100px; max-height: 80px;' src='/playlist/widget/form/templateimage/forecastio/weather-module3p' />
													</span>
													<span class='media-body'>Portrait - Current day, 4 day forecast</span>
												</span>"
 data-filter1-class="portrait">Portrait - Current day, 4 day forecast
											</option>
											<option value="weather-module4l" data-content="
														<img style='max-width: 100px; max-height: 80px;' src='/playlist/widget/form/templateimage/forecastio/weather-module4l' />
													</span>
												</span>"
											</option>
											<option value="weather-module4p" data-content="
														<img style='max-width: 100px; max-height: 80px;' src='/playlist/widget/form/templateimage/forecastio/weather-module4p' />
													</span>
													<span class='media-body'>Portrait - Current day, 3 day forecast</span>
												</span>"
 data-filter1-class="portrait">Portrait - Current day, 3 day forecast
											</option>
											<option value="weather-module5l" data-content="
														<img style='max-width: 100px; max-height: 80px;' src='/playlist/widget/form/templateimage/forecastio/weather-module5l' />
													</span>
													<span class='media-body'>Landscape - Current day detailed, 3 day forecast</span>
												</span>"
 data-filter1-class="landscape">Landscape - Current day detailed, 3 day forecast
											</option>
											<option value="weather-module6h" data-content="
														<img style='max-width: 100px; max-height: 80px;' src='/playlist/widget/form/templateimage/forecastio/weather-module6h' />
													</span>
													<span class='media-body'>Landscape - Current day details, 4 day forecast</span>
												</span>"
 data-filter1-class="landscape">Landscape - Current day details, 4 day forecast
											</option>
											<option value="weather-module6v" data-content="
														<img style='max-width: 100px; max-height: 80px;' src='/playlist/widget/form/templateimage/forecastio/weather-module6v' />
													</span>
													<span class='media-body'>Portrait - Current day details, 4 day forecast</span>
												</span>"
 data-filter1-class="portrait">Portrait - Current day details, 4 day forecast
											</option>
											<option value="weather-module-7s" data-content="
														<img style='max-width: 100px; max-height: 80px;' src='/playlist/widget/form/templateimage/forecastio/weather-module-7s' />
													</span>
													<span class='media-body'>Square - Forecast squared with background</span>
												</span>"
 data-filter1-class="square">Square - Forecast squared with background
											</option>
											<option value="weather-module-8s" data-content="
														<img style='max-width: 100px; max-height: 80px;' src='/playlist/widget/form/templateimage/forecastio/weather-module-8s' />
													</span>
													<span class='media-body'>Square - Detailed weather</span>
												</span>"
 data-filter1-class="square">Square - Detailed weather
											</option>
											<option value="weather-module-9" data-content="
														<img style='max-width: 100px; max-height: 80px;' src='/playlist/widget/form/templateimage/forecastio/weather-module-9' />
													</span>
													<span class='media-body'>Scale - Weather background only</span>
												</span>"
 data-filter1-class="scale">Scale - Weather background only
											</option>
										</select>
										<small class="form-text text-muted">Select the template you would like to apply. This can be overridden using the check box below.</small>
									</div>
								</div>
											<input class="form-check-input" type="checkbox" id="overrideTemplate" name="overrideTemplate" >
												<label class="form-check-label" for="overrideTemplate" accesskey="">Override the template?</label>
											</div>
											<small class="form-text text-muted">Tick if you would like to override the template.</small>
										</div>
									</div>
									<div class="row">
										<div class=" col-sm-12 template-override-controls">
											<p> With Override the Template selected enter your own text, HTML and CSS by using the Templates drop down menu in the tab header above.
 </p>
										</div>
									</div>
									<div class="form-group row template-override-controls">
										<label class="col-sm-2 control-label" for="widgetOriginalWidth" accesskey="number">Original Width</label>
											<input class="form-control" name="widgetOriginalWidth" type="number" id="widgetOriginalWidth" value="" />
											<small class="form-text text-muted">This is the intended width of the template and is used to scale the Widget within its region when the template is applied.</small>
										</div>
									</div>
										<label class="col-sm-2 control-label" for="widgetOriginalHeight" accesskey="number">Original Height</label>
											<input class="form-control" name="widgetOriginalHeight" type="number" id="widgetOriginalHeight" value="" />
											<small class="form-text text-muted">This is the intended height of the template and is used to scale the Widget within its region when the template is applied.</small>
										</div>
									</div>
									<div class="template-options template-selector-control">
										<div class="row">
											<div class=" col-sm-12 ">
												<p> You can change the appearance of this template using the options below.
 </p>
											</div>
										</div>
										<div class="form-group row template-option template-option-text-color d-none">
											<label class="col-sm-2 control-label" for="text-color" accesskey="">Text</label>
											<div class="col-sm-10 colorpicker-input">
												<div class="input-group">
													<div class="input-group-prepend">
														<i class="input-group-text input-group-addon" id="text-color_label"></i>
													</div>
													<input class="form-control" name="text-color" type="text" id="text-color" aria-describedby="text-color_label" value="" />
												</div>
												<small class="form-text text-muted"></small>
											</div>
										</div>
										<div class="form-group row template-option template-option-icons-color d-none">
											<label class="col-sm-2 control-label" for="icons-color" accesskey="">Icons</label>
														<i class="input-group-text input-group-addon" id="icons-color_label"></i>
													</div>
													<input class="form-control" name="icons-color" type="text" id="icons-color" aria-describedby="icons-color_label" value="" />
												</div>
											</div>
										</div>
										<div class="form-group row template-option template-option-background-color d-none">
											<label class="col-sm-2 control-label" for="background-color" accesskey="">Background</label>
														<i class="input-group-text input-group-addon" id="background-color_label"></i>
													</div>
													<input class="form-control" name="background-color" type="text" id="background-color" aria-describedby="background-color_label" value="" />
												</div>
											</div>
										</div>
										<div class="form-group row template-option template-option-shadow-color d-none">
											<label class="col-sm-2 control-label" for="shadow-color" accesskey="">Shadow</label>
														<i class="input-group-text input-group-addon" id="shadow-color_label"></i>
													</div>
													<input class="form-control" name="shadow-color" type="text" id="shadow-color" aria-describedby="shadow-color_label" value="" />
												</div>
											</div>
										</div>
										<div class="form-group row template-option template-option-footer-color d-none">
											<label class="col-sm-2 control-label" for="footer-color" accesskey="">Footer Background</label>
														<i class="input-group-text input-group-addon" id="footer-color_label"></i>
													</div>
													<input class="form-control" name="footer-color" type="text" id="footer-color" aria-describedby="footer-color_label" value="" />
												</div>
											</div>
										</div>
										<div class="form-group row template-option template-option-footer-text-color d-none">
											<label class="col-sm-2 control-label" for="footer-text-color" accesskey="">Footer Text</label>
														<i class="input-group-text input-group-addon" id="footer-text-color_label"></i>
													</div>
													<input class="form-control" name="footer-text-color" type="text" id="footer-text-color" aria-describedby="footer-text-color_label" value="" />
												</div>
											</div>
										</div>
										<div class="form-group row template-option template-option-footer-icons-color d-none">
											<label class="col-sm-2 control-label" for="footer-icons-color" accesskey="">Footer Icons</label>
														<i class="input-group-text input-group-addon" id="footer-icons-color_label"></i>
													</div>
													<input class="form-control" name="footer-icons-color" type="text" id="footer-icons-color" aria-describedby="footer-icons-color_label" value="" />
												</div>
											</div>
										</div>
									</div>
										<label class="col-sm-2 control-label" for="background-image" accesskey="">Background Image</label>
											<select class="form-control" name="background-image" id="background-image">
												<option value="none">None</option>
												<option value="fit" selected
 >Fit</option>
												<option value="stretch">Stretch</option>
												<option value="center">Centre</option>
											</select>
										</div>
									</div>
									<div class="background-select-list">
										<div class="row">
												<p>Select images from the media library to replace the default weather backgrounds.</p>
											</div>
										</div>
										<div class="form-group row pagedSelect">
											<label class="col-sm-2 control-label" for="cloudy-image" accesskey="">Cloudy</label>
												<select class="form-control" name="cloudy-image" id="cloudy-image"
 data-allow-clear="true"
 data-placeholder--id=""
 data-placeholder--value=""
 data-search-url="/library"
 data-search-term="media"
 data-search-term-tags="tags"
 data-width="100%"
 data-id-property="mediaId"
 data-text-property="name"
 data-filter-options="{&quot;type&quot;:&quot;image&quot;}">
This is where it gets fun…
Lines 639-???
<option value="" selected ></option>
<option value="95024"> ASLSupport and Practice Sessions</option>
<option value="">And the next option...</option>
... skip 100,000+ lines
This ends up enumerating all of the media in our Library for each Weather condition, for if I’m not mistaken a total of 10 times (13,210 items in library, so perhaps ~132,100 lines or more, depending on the formatting.
After that, there is some repetitive CSS code returned before the file is over.
Lines  ????-end (~7000 lines):
CSS related data that starts like this...
"buttons":{"Get Forecast":"formHelpers.requestTab("forecast", "/playlist/widget/tab/forecast/137225")"},"fieldActions":[],"dialogTitle":"Weather","callBack":"","autoSubmit":null,"success":true,"message":null,"clockUpdate":null,"login":null,"id":0,"extra":[{"id":"weather-module0-5day","value":"Landscape - Current day, 4 day forecast","main":"
						<div class="container ">
							<div class="main-panel">
								<div class="container-row">
									<div class="details-box text-center shadowed">
										<div class="big-icon">
											<i class="wi [wicon]"></i>
										</div>
										<div class="big-day">[time|D]</div>
										<div class="big-temp">[temperatureRound]&deg;[temperatureUnit]</div>
									</div>
 [dailyForecast|4|1]
									<div class="container-footer">
										<div class="powered">[Attribution]</div>
									</div>
								</div>
							</div>
						</div>","daily":"
						<div class="upcoming-days shadowed">
							<div class="small-icon">
							</div>
							<div class="small-temp">[temperatureMaxRound] &deg; [temperatureUnit]</div>
							<div class="small-day">[time|D]</div>
						</div>","css":"* {
 -webkit-box-sizing: border-box;
 -moz-box-sizing: border-box;
Whoosh, yes you’re right. I’ve reported it as a bug:
Good news (for some) is that it is solved in v4 as a side effect of the redesign. I’ve targeted the above to v3.3.9.
There are a few issues in there now, so we will try and get a maintenance release out in Jan.
Ah, darn. We aren’t quite ready yet for the leap to v4, but much thanks with backporting the fix to v3! We look forward to the release in January. Thanks again for taking the time to get to the bottom of this with us :slight_smile:
