Hello Dan,
Thank you for your help the last time. I find Xibo very awesome and easy to use, but I have some problems with.
1- When I create a composition that works well.
But when I created several composition: eg hairdresser, medical
practice etc, except the last step for the rest I lose the images and
thumbail and I can no longer run.
I have to put the template and all the images, yet they exist in the library.
I use the same xibo library for all my compositions.
I tried to use the multi-site method that you promote:
copy the directory and rename xibo with another repertoire xibo
library but I have not reference the error object .net framework.
PS I use the same PC for displays.
2 - I need to display them under video youtube but when I enable
cc_load_policy = 1
setting does not work (see embed code below).
But it works in manual when I press subtitle.
<Iframe
frameborder = "0" height = "100%" width = "100%"
src="https://youtube.com/embed/ZM7F35sbpPk?&cc_load_policy=1&autoplay=1&controls=0&showinfo=0&autohide=1&cc_lang_pref=fr&iv_load_policy=1"
allowfullscreen> </ iframe>
Thank you in advance for your help.
Guy
