I just want to know that if the new models like 49SE3KE is support running XIBO?
I don’t understand why the requirement of WebOs is 3.0 version ahead when those new model are not listed in support LG ?
We keep a complete list of supported models here:
The latest E series monitors are on that list, that run webOS 4.0 for Signage.
We require a signage line monitor to work. Consumer grade devices or LG displays that don’t run webOS are not supported and won’t work.
Could you confirm the 49SE3KE is supported ?
I don’t see it in the list
Only the models on the list are supported. The 49SE3KE is not on the list, so is not supported. It doesn’t run webOS at all!
The E series model that you need is the 43/49/55SH7E or 32/43/49/55SM5KE as listed in that guide.
Hi Alex, I want to use Xibo player in LG 43UJ6300 that run WebOS 3.5, but is not listed in compatible list. I must find another one? i live in Uruguay (S. America) and we have just one provider with few TV models.
All the webOS panels that are compatible are on the list.
The model you list isn’t a signage panel and doesn’t have the correct firmware or hardware for the Player to run. You must purchase a device from the list linked above.
