Kiosk mode for android
For the original poster (OP) to fill in:
Introduction
Kiosk mode or lockdown for Xibo android player
User Story
We have several customers who wants to use interactive screens for browsing a certain website or an app and wants to limit the user from exiting the application or browse another website. We use Xibo android player on the interactive screens but Xibo lacks the functionality for Kiosk mode or lock the app so that the customer cannot exit it the app without a pin code. I recall that Risevision had a lock option in their app so the user were forced to know the pin code in order to exit the app. I believe it would be great if Xibo add a function of Kiosk mode or lockdown with a pin.
Whilst we don’t claim Xibo for Android has a full kiosk mode, it does have some features that might help you.
In the Display Settings Profile in the CMS, create a new profile for Android devices and apply your normal settings to it. Then on the Advanced tab, change Action Bar Mode to “Hide” and Action Bar Display Duration to say 5. On the General tab, set “Password Protect Settings” with a password of your choice.
Apply that profile to a device, allow it time to collect once, close Xibo for Android and set it as the launcher on your device, and then reboot.
Now you should see the Xibo action bar appear once at startup for 5 seconds and then after that touching the screen won’t cause it to appear at all. If someone does catch that 5 second window where the action bar appears, they will need a password to access the device settings (to change the launcher back again so they can access other apps).
Thanks a lot for the suggestion which might be a half solution. The better solution would be to lock the Xibo app (as an option) so that it requires a pin code to exit from the app. I truly believe that this feature would be appreciated by many customers.
Hello Team Xibo,
I am currently in the middle of a test project for the use of Tocuscreens with Xibo. And I come to the same conclusion as Micke_Salloum: A possibility that prevents users from leaving the Xibo app and entering the Android settings would be necessary for my project. Unfortunately, the solution proposed above does not prevent a user from switching to the OS.
Are there any solutions for this in the meantime?
Can Xibo handle it if I install a kind of kiosk app (e.g. https://www.fully-kiosk.com/) on Android/the DS devices, which only takes care that the user does not leave Xibo?
Or are you planning something?
Best
Heiko
As a supplement, in case anyone is looking for it too:
Since I needed a quick solution, I solved it like with the additional installation of an app that allows the user to use the Xibo output via touch but only allows access to the OS with a password.
@heiko Which app did you use for that exactly?
Hello @CraftedInSteel ,
at this time, I used the FULLY SINGLE APP KIOSK.
