i’m trying to installa Android App on Android TV 11. I receive the same message with 2.12 or 3.0.0 version.
In the same device (Mecool KM7) there’s another app, myself developed, that start on boot without problems.
2022-07-07 06:29:34.950 560-619/? I/SystemServerTimingAsync: InitThreadPoolExec:Update app-ops uidState in case package com.signage.mkeyekwwkm changed
2022-07-07 06:29:35.699 560-560/? V/StorageManagerService: Package com.signage.mkeyekwwkm has legacy storage
2022-09-06 14:44:00.976 560-588/? I/ActivityManager: Start proc 2971:com.signage.mkeyekwwkm/u0a75 for broadcast {com.signage.mkeyekwwkm/uk.org.xibo.alarms.ReceiveBootCompletedReceiver}
2022-09-06 14:44:01.090 2971-2971/? W/nativeloader: target_sdk_version is 28 is_shared is 0 java_library_path is /data/app/~~NqaActwK6eihB2xDriQ55Q==/com.signage.mkeyekwwkm-WZPVaDFhCZF2IPq7oAWEkA==/lib/arm permitted_path is /data:/mnt/expand:/data/user/0/com.signage.mkeyekwwkm
2022-09-06 14:44:01.184 2971-2971/? I/ACRA: ACRA is enabled for com.signage.mkeyekwwkm, initializing...
2022-09-06 14:44:13.285 560-881/? I/ActivityManager: Killing 2971:com.signage.mkeyekwwkm/u0a75 (adj 985): empty #18
For more details i’ve found this Expetion in Devel version.
2022-07-07 06:29:36.156 797-797/? E/AndroidRuntime: FATAL EXCEPTION: main
Process: com.signage.mkeyekwwkm, PID: 797
java.lang.RuntimeException: Unable to instantiate application uk.org.xibo.player.Xibo: java.lang.IllegalStateException: SharedPreferences in credential encrypted storage are not available until after user is unlocked
at android.app.LoadedApk.makeApplication(LoadedApk.java:1244)
at android.app.ActivityThread.handleBindApplication(ActivityThread.java:6683)
at android.app.ActivityThread.access$1300(ActivityThread.java:237)
at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1913)
at android.os.Handler.dispatchMessage(Handler.java:106)
at android.os.Looper.loop(Looper.java:223)
at android.app.ActivityThread.main(ActivityThread.java:7656)
at java.lang.reflect.Method.invoke(Native Method)
at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:592)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:947)
Caused by: java.lang.IllegalStateException: SharedPreferences in credential encrypted storage are not available until after user is unlocked
at android.app.ContextImpl.getSharedPreferences(ContextImpl.java:494)
at android.app.ContextImpl.getSharedPreferences(ContextImpl.java:479)
at android.content.ContextWrapper.getSharedPreferences(ContextWrapper.java:188)
at android.preference.PreferenceManager.getDefaultSharedPreferences(PreferenceManager.java:545)
at org.acra.prefs.SharedPreferencesFactory.create(SharedPreferencesFactory.java:4)
at org.acra.ACRA.init(ACRA.java:17)
at org.acra.ACRA.init(ACRA.java:5)
at org.acra.ACRA.init(ACRA.java:4)
at org.acra.ACRA.init(ACRA.java:3)
at uk.org.xibo.player.Xibo.attachBaseContext(Xibo.java:2)
at android.app.Application.attach(Application.java:351)
at android.app.Instrumentation.newApplication(Instrumentation.java:1159)
at android.app.LoadedApk.makeApplication(LoadedApk.java:1236)
This happens when the application starts before the device has been unlocked, which it shouldn’t do.
The only way to run apps before the device has been unlocked is to support “directBootAware”, but this adds a lot of complexity to the solution, and there is nothing Xibo needs to do before the device is unlocked, so it shouldn’t be necessary.
So the answer is - we need to find out why Xibo is being started before the device is unlocked.
Your app works because you have android:directBootAware="true" in your manifest. This is not something we can support as it causes issue with other parts of Xibo.
According to the documentation we shouldn’t need to use android:directBootAware="true" unless we try to access storage before the user has unlocked the device - we don’t do this!
we access storage once BOOT_COMPLETED is sent, which should be after the device is unlocked
it is strange for a digital signage box to start up locked anyway, most don’t
Make sure you don’t have Xibo set as your Launcher!
