I would like to disable the client information screen one special client completely. Is there a way to do this?
Kind regards
Helge
Kind regards
Helge
I don’t think this field can be empty - ie there needs to be a key assigned to it (‘i’ by default), but you can enable the checkbox that it will also need crtl (ie ctrl+i) perhaps that will help?
Thank you, but the ctrl key is not the solution for me.
Is it possible to disable the funciton which will start the information screen in the source code of the client?
This would be the perfect solution for me. I think I can build a custom player with the source code, but I dont know in which file the function is defined.
Kind regards
Helge
