Javascript in xibo
Can i embbeded this in Xibo??
How is the plan that the site is on screen?
Markus
Yes you should be able to do that - although you will want the new fussball bit in the EmbedInit function provided when you create a fresh embedded widget.
Hi dan, thanks for your answer. Can you create a Screenshot how i must copy in which field in the xibo embedded link.
That’s great when you can do this. I dont know what i musst copy in which field or part.
