Having issues with the layout design not showing correctly within IE, Chrome and FireFox browsers.
All that is displayed is as per the attached screenshot
That doesn’t look like a recent CMS version. What version is it please?
That looks normal to me then in that case.
For your info, 1.7 is end of life and no longer supported or maintained. It’s more than 5 years old and likely won’t work with more modern browsers. You should look to upgrade in the first case - ideally with a copy of your existing data.
Hi Alex,
No worries. I haven’t had much to do with Xibo at all, can you advise on the steps on how to upgrade it?
https://xibo.org.uk/docs/setup/upgrading-the-cms
You’d have to go from 1.7 to 1.8, and then from 1.8 to 2.3.
In the process our recommendation would be to swap over to using Docker, in which case you’d do this:
https://xibo.org.uk/docs/setup/upgrade-and-switch-to-xibo-for-docker-install
Initially with 1.8.13 and do a normal upgrade to 2.3.5
Thanks Alex,
I will see how I go, much appreciated
