Issue with RSS Images in v4
I just upgraded Xibo CMS from 4.0.9 to 4.0.11. The RSS feeds are working, but without images. Even the Xibo RSS (Xibo Media RSS Test Feed) does not show the enclosure tag images. Am I the only one?
BTW: In preview mode the images are display fine.
same here.
In version 4.1.2 is this still an issue. I thought I was the only one, cause there is almost nobody replying with the same problem. RSS feeds are working fine in version 2.3.9, but not is 4.x.
Is there someone using RSS feeds with images fine in XIBO cms version 4.x? And do you want to solve this together with me? Thanks in advanced.
This is a follow up regarding this issue. After some further tests and troubleshooting, the issue Digin was experiencing is now resolved. The issue was related to their XTR/Tasks not being configured. After setting cron tasks and waiting for them to complete, the RSS images started showing on their Xibo for Windows player.
Thanks DanBW for your help. And after a few days it is still working.
Unfortunately the RSS feeds are not always working. Every day, when I do not manual update the layout, the following message appear in the log:
getData: Failed to get data cache for widgetId 991, e = Cache not ready
Then the ’ No data message’ will be displayed instead of the RSS feed. Any idea?
Is something wrong with the task ‘Widget Sync’ or ‘Drop Player Cache’?
The next ‘Drop Player Cache’ task will run 1-1-2026. That is a long time.
