Hi everyone,
I’m encountering an issue while attempting to change the default layout using the Xibo API. I’m utilizing the defaultlayout endpoint with the display ID, as shown below:
{{baseUrl}}/api/display/defaultlayout/21
Interestingly, I can successfully perform this action using Postman. However, when I try the same operation through my web application, it fails to work. Initially, I faced CORS origin issues, which I resolved by implementing a proxy to bypass them.
However, I’m now consistently receiving the following error message:
“error”: 404,
“message”: “LayoutId is 0”,
“property”: null,
“help”: null
Here are the details of the request:
- URL:
http://172.24.100.46/api/display/defaultlayout/21 - Request Body: Form Data (view source to see URL-encoded data)
layoutId: 125
- Headers:
'Content-Type': 'application/x-www-form-urlencoded''Authorization': 'Bearer ' + accessToken
Has anyone else encountered a similar issue? Any insights into what might be causing this problem would be greatly appreciated.
P.S. The Xibo server is running on a Linux machine, in case that’s relevant.
Thank you for your help and suggestions.
Best regards,
Shaul
