Is Xibo support's p5.js library?
I’m using p5.js library to read some data from localhost server. I wanted to know that-
Is xibo supports p5.js library or not ? If yes, How I can use it in xibo player at client ?
My client is using Ubuntu 16.04 and 18.04.
Thanks & Regards
Mitesh Dube.
Xibo doesn’t use p5.js no. I’m afraid we can’t advise you on how you might use that library outside of Xibo.
Any options in xibo other than p5.js library ?
Xibo doesn’t expect you to code anything in javascript, so no there’s no options for alternatives.
Internally Xibo uses jQuery but for most purposes we don’t expect you to interact with it directly.
