Is there a language file for spanish?
Hello! I am learning about XIBO, i will need to use it in a project soon.
I was wandering if it exists a SPANISH language file? If not, which is the original language file? so i can translate it manually.
Thanks and regards,
Hi
Yes there is a Spanish translation and Xibo ships with that by default. It will use the preferred language on your web browser to detect you want webpages shown in Spanish and should switch automatically. Alternatively there’s a global setting in the CMS settings to force a particular language and disable the browser automatic detection.
All translation happens over in Launchpad:
https://translations.launchpad.net/xibo
https://translations.launchpad.net/xibo/1.7/+pots/default/es/+translate
If you would like to contribute extra translations, pop them in to Launchpad and they’ll be included in the next release automatically.
Alex
Hi Alex, thank you very much!
