Introducing Xibo Modules — An open-source TypeScript toolkit
Hi everyone!
I’ve been working on Xibo Modules, a toolkit that makes developing custom Xibo modules feel more like building a regular software project.
It provides a CLI, TypeScript abstractions, automatic XML generation, Vite integration, and a structured build pipeline supporting everything from simple static widgets to more complex applications.
The project currently targets Xibo 4.4.x and is still under active development. I’m now working on a local development environment to preview modules without deploying them to a CMS.
Feedback and contributions are very welcome!
:link: GitHub: GitHub - ManOguaR/xibo-workspace · GitHub
:rocket: Quick update: xibo-modules v1.0.0-dev.5 is available!
The project has reached a functional development milestone.
You can now scaffold a module, build it and run it locally using the CLI:
npx xibo new my-module ./my-module
npx xibo build
npx xibo run
The core build pipeline is working, including TypeScript companion applications and local previews.
It’s still a development prerelease, with full XML coverage, packaging and CMS validation in progress.
Still running Xibo 4.4.x in production? This toolkit is being built specifically for you.
Check it out: GitHub - ManOguaR/xibo-workspace · GitHub
Feedback and contributions are welcome!
