This is more of a Diary entry of my journey through this Madness.
The End Goal is to make Xibo do something it shouldn’t.
I am wanting to create a GUI using Xibo Widgets and Interactive areas.
I know I’m going to run into problems, but what’s life without a little Challenge? So come with me on this mad challenge and share in my Success/Failure!
Im using V4 and will be using an Android based touch screen as the Player.
The Plan of attack…
Create a Layout with a touchable area.
Have the touchable area jump to another layout.
Figure how to use the menuboard system.
can I use that as a makeshift GUI?
Get the Items into the Media library.
Feel Free to Chime in if I’m covering ground that’s already documented…
the icons do pop up for a bit with the video playing in the background but they then disappear…
the Invisible html buttons work though and you can navigate the GUI…
I’m just struggling with the layering…
any advice?
