Installing xibosignage/xibo-cms docker container on Synology
Hi all,
I’m trying to install the Docker container on a Synology NAS running DSM 7.1.1. I’m currently trying from the Docker app, where I searched the registry, downloaded the image, and then created a container with it using the wizard. If this approach isn’t going to work on DSM, how should I go about this?
The install instructions state I should be using root, but I don’t believe I can use actual root anymore on Synology.
Does anyone have this running? Thanks!
Hi!
This was written a long time ago, but might still be useful for you:
