HI can i get the linux player installer ? i cant get from the website. nothing happens when i click the linux downloading installer. thank you.
Hi, the link seems to be working ok? Install Xibo Digital Signage Player on Linux | Snap Store
What are you seeing when you click the button?
If you have snap installed on your Linux machine, you should be able to open a terminal and enter
sudo snap install xibo-player to install the player, so maybe worth giving that a try.
