Hello ,
I remove xibo 1.7.8 CMS and trying to install XIbo 1.8 alpha3 CMS on CentOS machine.
I copied my Xibo folders in /var/www/html/Xibo/ and also created library function.
When i hit https://myIPAdress/Xibo on browser : It gives folder list thats it which shows parentry directories.
I also tried https://myIPAdress/Xibo/web , It gives error
" Fatal Error - sorry this shouldn’t happen. SQLSTATE[28000] [1045] Access denied for user ‘xibo’@‘localhost’ (using password: YES) "
I Installed Mysql properly and also PHP version 5.5 .
Please help me to solve this .
Regards,
Sudheer
hello,
Can u please tell whether its possible to install Xibo 1.8 CMS on centos 6 32 bit machine.
I tried and faced issues and i reported those also .
Can u please suggest anything to solve my errors
dan
June 20, 2016, 10:14pm
3
You need to read the manual first and understand the installation instructions we’ve provided. http://xibo.org.uk/manual-tempel/en/install_environment.html
It sounds like you haven’t modified your DocumentRoot
to serve the /web
folder and it sounds like mod_rewrite
isn’t enabled.
If you are non-technical it might be better to wait for xibo-docker
to be completed and use that instead.
