Hi at the Xibo Community
I hope I can get some help with the following issue, it drives me a little bit crazy. Did search the internet and community, but could not find a solution for the problem.
Installation Method
Custom install
Operating System
Ubuntu 20.04.4
Apache 2.4.41
PHP 7.4.3
MySQL 15.1
I’m getting “404 Not Found”, when trying to install Xibo 3.1.1, tried the installation on 2 different servers, same issue. I can on the same servers install Xibo 2.3.16, no problems here - but I will like to use the latest Xibo version.
This is the exact output
404 Not Found
The application could not run because of the following error:
Details
Type: Slim\Exception\HttpNotFoundException
Code: 404
Message: Not found.
File: /var/www/clients/client4/web4/web/xibo/vendor/slim/slim/Slim/Middleware/RoutingMiddleware.php
Line: 91
Trace
#0 /var/www/clients/client4/web4/web/xibo/vendor/slim/slim/Slim/Middleware/RoutingMiddleware.php(58): Slim\Middleware\RoutingMiddleware->performRouting() #1 /var/www/clients/client4/web4/web/xibo/vendor/slim/slim/Slim/MiddlewareDispatcher.php(147): Slim\Middleware\RoutingMiddleware->process() #2 /var/www/clients/client4/web4/web/xibo/vendor/slim/slim/Slim/Middleware/ErrorMiddleware.php(107): class@anonymous->handle() #3 /var/www/clients/client4/web4/web/xibo/vendor/slim/slim/Slim/MiddlewareDispatcher.php(147): Slim\Middleware\ErrorMiddleware->process() #4 /var/www/clients/client4/web4/web/xibo/vendor/slim/slim/Slim/MiddlewareDispatcher.php(81): class@anonymous->handle() #5 /var/www/clients/client4/web4/web/xibo/vendor/slim/slim/Slim/App.php(215): Slim\MiddlewareDispatcher->handle() #6 /var/www/clients/client4/web4/web/xibo/vendor/slim/slim/Slim/App.php(199): Slim\App->handle() #7 /var/www/clients/client4/web4/web/xibo/web/install/index.php(101): Slim\App->run() #8 {main}
[Go Back]
Thanks.
