I have run through the install document for iis. When I launch xibo for the first time all checks are ok except the File System Permissions. The message is: Write access required for settings.php and install.php.
I have installed xibo 1.7.5.
I looked through the posts and it seems there needs to be a permission for the account running iis, I am weak on the iis side and was hoping someone could help me check exactly what I need to check.
Any help would be appreciated.
Thank you
