Does Xibo have the option to display InfluxDB or Chronograf dashboards? My company has just started populating Chronograf dashboards based on InfluxDB, would be good to display on remote screens via Xibo if I can.
Thanks!
Thanks!
Thanks for your message Damo.
Xibo for Windows may be able to display the dashboards you mention but this will require testing to be sure the performance meets your requirements. Some users have tested with other dashboards, for example Grafana with varying results.
If you decide to test this on your player, I would recommend the following tips in case you encounter an issue:
I hope your tests are successful and you are able to display InfluxDB and/or Chronograf on your Xibo players. There’s no pressure to do so but if you could update this post letting the community know what player version, Windows version you used and whether it was successful, that would be very helpful for others who may be considering a similar setup.
Thanks Dan, will keep you all updated if I get it sorted
