So I have configured a Dataset on another CMS and it works great… installed a new CMS and imported the Layout with the dataset, but it’s fetching the data and I can’t figure it out…
Here is what I have looked at:
When I run “Test Data URL” in the dataset config it all looks good. “processed”: shows me correct data and columns.
I decided to clear cache and switch on DEBUG logging to see what is happening, here is what I get:
2618 | ce5eb5c | 2021-01-26 00:00 | CONSOLE | GET | DEBUG | / | #0 /var/www/cms/lib/XTR/RemoteDataSetFetchTask.php(109): Xibo\Factory\DataSetFactory->callRemoteService(Object(Xibo\Entity\DataSet), NULL) #1 /var/www/cms/lib/Controller/Task.php(367): Xibo\XTR\RemoteDataSetFetchTask->run() #2 /var/www/cms/lib/Controller/Task.php(462): Xibo\Controller\Task->run(‘6’) #3 [internal function]: Xibo\Controller\Task->poll() #4 /var/www/cms/vendor/akrabat/rka-slim-controller/RKA/Slim.php(79): call_user_func_array(Array, Array) #5 [internal function]: RKA\Slim->RKA{closure}() #6 /var/www/cms/vendor/slim/slim/Slim/Route.php(468): call_user_func_array(Object(Closure), Array) #7 /var/www/cms/vendor/slim/slim/Slim/Slim.php(1355): Slim\Route->dispatch() #8 /var/www/cms/vendor/slim/slim/Slim/Middleware/Flash.php(85): Slim\Slim->call() #9 /var/www/cms/vendor/slim/slim/Slim/Middleware/MethodOverride.php(92): Slim\Middleware\Flash->call() #10 /var/www/cms/lib/Middleware/Xtr.php(58): Slim\Middleware\MethodOverride->call() #11 /var/www/cms/lib/Middleware/Storage.php(48): Xibo\Middleware\Xtr->call() #12 /var/www/cms/lib/Middleware/Xmr.php(37): Xibo\Middleware\Storage->call() #13 /var/www/cms/vendor/slim/slim/Slim/Slim.php(1300): Xibo\Middleware\Xmr->call() #14 /var/www/cms/bin/run.php(125): Slim\Slim->run() #15 /var/www/cms/bin/xtr.php(9): require(‘/var/www/cms/bi…’) #16 {main} | |
2617 | ce5eb5c | 2021-01-26 00:00 | CONSOLE | GET | ERROR | / | Error syncing DataSet 1. E = Unable to get Data for Parking Feed Dataset because the response was not valid JSON. | |
2616 | ce5eb5c | 2021-01-26 00:00 | CONSOLE | GET | DEBUG | / | JSON decode error: json_decode error: Syntax error |
On the next fetch the message that comes through is “Skipping due to MD5” which is due to no change I guess and the reason I cleared the cache.
I put my json output through a json validator and all is ok.
My data has no root (ie Empty) and comes in as an array.
As I said this is working on another CMS so I’m not sure what the issue is.
Any help would be appreciated.
