Hello everybody.
When i imported a CSV file from Dataset and in this file have words with accentuation only part of the word is imported.
Example:
This is part of my CSV File;
And so that is imported;
This is a possible Bug?
Thanks.
Hello everybody.
Example:
Thanks.
It may well be a bug - can you please try two things:
Thanks!
Hi Dan.
Thanks for response.
I will do this test and give a feedback.
This is the link for download the file
Hi - when I opened the file it wasn’t encoded in UTF8, which means that the special characters in the file were not encoded correctly.
I opened the xls
and re-saved to csv
but made sure I selected UTF-8 as the encoding.
Everything imported as expected once i’d done this.
