Imbedded html does not appear on screen, but does in layout
I’ve imbedded HTML code from juicer to show a Instagram feed on a layout. In this layout I added a background jpeg. When I test the layout in the crm all is fine. When I check the screen:
  • First there was no background, only the imbedded html feed
  • I added the jpeg as picture and layered it behind the html layer, now it only shows the jpeg
Why does the screen not show the same as the layout? What can I do? Hope someone can help.
Which CMS version?
What type of player? And version ?
Can you take a screenshot of your layout?
CMS version 4.0.8.
Xibo for Android v4 R403
